oklacountryboy87
- Aug 22, 2010
- 14
1979 85 HP Evinrude had it out on the water last week and would only go about 10 miles and hour it planed out but wouldnt go very fast. I posted about maybe fuel problems well i took the carbs off and took them apart to clean everything. i did not buy a new carb kit yet because im no sure how much further i need to get into the motor or is it just the two flaps? I also been reading that maybe its the hub. i did check the lower unit fluid from the bottom hole with the screw when i lossened it it had pressure and squirted out some on the floor but there was no metal shavings or anything in the fluid. I also put the motor in gear and the prop spun both ways freely not locking in any direction but i also have the carbs off so the cables are freely hanging would that make a difference or do i need to put everything back together and retry the prop spin again? Also i was wondering how do you know the difference between a spun hub and coupler? the rpm gauge does not work so couldnt tell you what it was spinning at wot. This boat was bought with the guy telling me it was lake ready but has become a nightmare
