NOOB2Boats
- Aug 29, 2010
- 17
Guys, I just found this forum a day ago so please forgive me for not researching properly. But, yesterday I purchased a 1970 Tidecraft (the body on the title says "VS") but it looks like I would assume a tri-hull. He stated that he "Redid the floor". Upon inspection, lol or lack there of. He had laid new ply wood and had put new fiberglass over the top of it. It looked good, and the rest of the boat looked fine. But, I got it home and went to park it the back yard when I noticed when I tilted the trailer up water started to pour from the back. I lifted it up all the way that I could, and I would say about a gallon to two gallons of water poured out. The previous owner who stated that he bought it from someone about 6 months ago and had never had it in the water due to engine troubles. But I sent him this email this morning:
"Donald,
I just bought the boat from you yesterday. I appreciate the transaction. However when I got it home I tilted the trailor high off the ground and water seemed to drain from the inner hull. I was wondering when you took the flooring out and was replacing it, was the foam soaked or did the stringers look like they needed replaced? Im just curious because I would rather not take the flooring up and look if I dont have to. I bought it as is so if there is an issue its my problem. But i was just curious to the extent of the repair that Im going to have to do.
Thanks for the information "
He replied:
"the stringers are good,and there isn,t much foam in the hull..right where the battery was sitting there,s a small hole that i forgot to plug that's where the water is most likely getting in..when i put the floor in it was dry.i,m pretty sure when all the water is out just plug that small hole that way the water shouldn,t get back in"
So my question for you guys... Should I trust this guy, or rip up the floor and check for myself? And from that.. What the hell do I do next?
"Donald,
He replied:
