First the history, I have my brothers 1990 Johnson GT200 and I have had problems with it going into slow mode. First time it pretty much stayed in slow mode for 10 miles, right from the get go, but no alarm. 2nd time it was intermittent, mostly it would open up, sometimes slow mode but never an alarm. I got to thinking electrical interference since there was no alarm (I grounded the temp sensor and the alarm went off, so it works) so I checked the wires and one of the sensor wires was touching a plug so I thought ah-ha, there is the problem. Fixed that, took it out and it ran pretty good, it had a little miss that would come and go, figured that was just a little bad fuel (the boat had sat for a while) or something, but then it went into slow mode after about 10 minutes and this time the alarm went off. I shut it down and felt the heads, they were hot like a really hot cup of coffee, but they didn't burn. The motor wouldn't start back and I was getting worried when I realized that the tanks were hooked up backwards and I had been running on the tank that was now empty. I switched over and it ran in slow mode for 20 minutes back to the ramp, with alarm. I took the water pump out today and it was perfect and so was all the housings. It has a gauge for water pressure and it runs about 3 psi at idle to 13 at WFO. That seems maybe a tad low, but should be enough I figure. It also pee's well. I am thinking either a bad sensor or when the boat was running out of fuel it was running a little lean and got a little hot, but shouldn't it have cooled down? Going to run back out to the lake today with a IR temp probe. Any other ideas? I hope I got all the goodies lined back up putting the foot back on, it seemed pretty hard to get her back up in there.
