emoney
- Jul 19, 2010
- 2,551
Motor is a 1983 Chrylser 50hp, model# 507H3D
Ok, so once I got my shift linkage fixed and could put the motor in neutral,
I decided to do a compression test. Went to Harbor Freight and bought a cheap, $10.00 test, followed the instructions by removing both plugs, threaded tester into top cyclinder 1st, let it turn over 7-8 times and got 125-130 lbs. Proceeded to the bottom and got 100 lbs. Little odd thing here, but to verify the top cylinder, I went back to it and this time got over 130lbs, closer to 140.
Assuming I did this right, and it read that there was only one way to do it, what's next? I'm about to order a manual (any tips there appreciated), and
I don't might tearing it apart, if I know what to do. Guide me oh wise ones.
And thanks in advance, as this forum has already proven priceless on my 1st repair!
