Possible Overheating?
quigley5190
I have a 1997 Sea Ray Sundancer with twin 4.3 L Mercruiser V6. Both engines at idle run around 150 degrees but when running at about 3400-4000 RPM the temperature is around 170-180 Degrees? Is this normal? If not what could be causing it. I changed the thermostats and water pumps/impellers at the beginning of the year.
paultjohnson
Re: Possible Overheating?
Dunno but my 86 4.3 runs a perfect 140 -145 no matter if its at idle, WOT, on muffs or in the lake. With a 143 Deg stat.. FYI
