d. mcgrady
- Aug 28, 2010
- 2
I have a 1989 Evinrude 200XP. The engine starts and idles good. When you put it in gear and try to accelerate, it goes up to about 2000 rpms and don't want to go any farther. Sometimes, if you keep it wide open, it will eventually plane out, then the engine really runs great....lots of power. I have had it to 3 marinas. Have replaced stator, trigger, regulator, wiring harness, power pack, carbs cleaned and rebuilt, compression check....still have the same problem. It acts like it is running out of fuel. I have had the fuel tanks drained and cleaned. I can't fine any obstructions in the fuel line. The marina mechanics just keep replacing parts and this has been extrememly expensive. $3500 later, my motor still won't run right. I am looking for help. They are telling me now to replace the VRO pump. Could this be the problem? When the boat runs so good at WOT, if you can get it on plane. Any help will be greatly appreciated. There are no warning alarms going off.
