here is the problem, motor is bogging out when i try to open it up. runs at 3/4 speed fine. changed impeller and it ran fine now it is doing it again. My son took it out, pulled the cover off and it ran fine. put cover back on and it started to do it again but not as bad he said. could the air flow to the carb be restricted or is it something else. Thanks in advance
