Hey friends, have a post going on "recommissioning my boat after sitting for 5 years. Its an 89 85hp Force H model. I've been through the fuel pump, new starter, solenoid, circuit breaker, battery. I did finally clean the carbs which did have debris. I did not clean the reeds since they looked so prettity and shiny.
Man, its trying to start. At first it would fire once and quit. Then it started to sound like it was going to start. I would think it is running until I dropped the key and it would stop.
It seems like a fuel issue although it got less and less fire as my battery wore out. I haven't tried jumping it from the car yet. If I do, I'm to disconnect the red wire from the rectifier according to the CDI troubleshoot. Can anybody confirm that?
My plugs just seem so dry. When I put in a new diaphragm for the fuel pump. There was a big spring pushing the diaphragm out. The manual and here on Iboats did not include that spring with my model. I see it on the "B" and L drive models. I did leave that spring off. Also my new ball from my new gas tank through new lines does not stay firm. It seems firm at first but checking it after cranking, it needs to be squeezed again a couple of times.
Am re-charging my battery since I think I was getting the near start when it was fully charged and will try again in the am.
I've had the boat since 7/4. I feel so close. Please get me there. Hurricanes are coming and I may need to skeedaddle.........
