mike64
- Apr 10, 2008
- 1,042
I was starting my boat at the dock and it turned over and almost caught on the first try. Figured a little more throttle and the second turn of the key would start the motor right up, but I turned the key again and nothing-- no crank. Turned out the 20 amp fuse was blown. When I replaced it, the second fuse blew immediately.
Motor was running fine all season up till then. I haven't made any changes to the electrical system. What's the most likely culprit-- bad wire? Fried ignition switch? I also wonder if the fuse was the wrong one-- the shortest 20 amp fuse I could find at the hardware store was a little longer than the one I was replacing, and I couldn't close the connector with the longer fuse in. Is there a certain TYPE of 20 amp fuse I should be using?
