Okay here goes. Needed some extra drain plugs for my new to me Mercruiser 3.0. The guy at the boat store sold me draincocks cause they were a whole lot EASIER! The drain hole in the block has a 1/2" brass fitting that screws into the block that the 3/8" brass plug screws into. Well of course, I sheared off that 1/2" brass fitting trying to take it out to install the 1/2" draincock. After an hour of gut wrenching contortion I was able to get the old plug to thread back into the brass threads left in the block. I checked it with muffs and no leaking. I go back to the boat store and get a 3/8" draincock to put back in the brass threads left in the block. I try to put the 3/8" draincock in but it's crossthreading the draincock threads. So I stopped and put the old plug back in (checked it, no leaks). Cause I'm going to the lake tomorrow if I have to weld the damn hole closed and drill it out later! So my question is THIS WINTER should I buy a 3/8" NPT tap & die and try to clean up the brass threads that are still in the block, try to get the 3'8" draincock in, then LEAVE IT ALONE. Or should I drill out the brass threads and tap the iron block for a larger draincock?
