Dodgerdavn
- Jul 8, 2003
- 13
Hello!,<br /><br />I have a '99 Reninell 170 with a 4 cylinder Volvo-Penta set-up. On several occasions the boat has become stuck in neutral. We took it to a boat shop, and the lubed the cables at the outdrive (are those at the top?) What was happening was whe pushing the button in the center of the throttle box, after returning the throttle lever to a neutral position, the button would not pop back out. Well, anyways, he said he lubed the cables and it should work ok. It did for a while. As a matter of fact, the throttle lever was tighter, alsmost too tight. Since then, is has happened a few more times. Does anybody know what I can do to fix this, or lube the cables myself? Thanks for the help!,<br />Dave
