Re: 85 johnson not idleing
Sounds to me like you have a couple of issues going on, sounds like the fuel line is restricted in some way, to eliminate this, get a clean hose with a known good or new primer bulb, bypass any quick connect fitting by hooking the hose directly into the inlet side of your fuel pump. Take the other end of the hose and stick it into the fill mouth of a clean gass can and try to start and see if that makes a difference. The gas pouring out of the bottom carb could be a stuck or misadjusted float. I would go through the carbs again to make sure everything is right.
