1988 searay 135 outboard cracked block
phillip79
does anyone know where i can find just a block for this engine or what other size block will interchange with this engine
Faztbullet
Re: 1988 searay 135 cracked block
I/o or outboard???
phillip79
sry its outboard
Faztbullet
Re: 1988 searay 135 outboard cracked block
If you need a block any 1988-92 135/150 block will work. Most blocks can be repaired unless casting is broken....
phillip79
where can i find just the block at been searching the web with no luck
Faztbullet
You want a block that is machined and ready to assemble or one you can do your own repairs to?
phillip79
machined and rdy if i can or a good used block i can hone and prep myself .first time working on boat engines but have been turning wrenches on cars for about 15 years.
