Eclipse223
- Apr 12, 2010
- 13
So 1988 Merc 1115 on a 1987 Stratos 179 will run great at top speed will run when i put it in neutral it will rev but to get boat up to planing i have to put 2 people up in front of the very front of the boat and then it just revs then dies revs then dies not totally dies but looses all power. I had a compression test done and all of them are 130 but number 5 is like 105 110. The guy looking at it said it had no fuel filter on it. And said it didn't need one. so i am lost on what to do he is cleaning the carbs up and i will go try it again i put a 5 blade prop on it one of those HIghFive props came with the boat i think its a 21 or 19 im not sure. i use to have a 3 blade on there but i wanted to see if the 5 blade helped. and it did not help at all. So the next step if this does not work?
Thanks so much guys!
Brien
Brien
