Hi,
Brand new to the site. I have read a ton of the topics on tilt/trim but have not found anything to help me thus far, would appreciate some advice.
I have a 1980 Evinrude 115. THe problem is the tilt/trim. It will go down with absolutely no issues but will not raise back up. I don't get a click or anything. It started a little while back working fine, then about 1 out of 5, then about 1 out of 10, 1:20, and now pretty much one out of 50 times it will "click" on. When it does 'turn on' it works fine without hesitation.
I thought that it may be the switch on the throttle, but you can hear/feel it click and engage. I don't know how to test this.?
I have cleaned every connection.
Couple of questions: If the motor lowers, can it be the tilt/trim motor (can just the 'up' option go out?)?
How can I test the switch on the throttle to see if that is the issue?
Other suggestions?
Other suggestions?
