We just put in a new ignition switch and power pack on our 1989 Evinrude 70hp
E70TLCEM. It idles great, and even when I lift the fast idle lever it does fine. BUT we went to the lake and past about 1/4 throttle it begins to build up RPMs then tries to cut out a little. This repeats, but is sporatic. It almost sounds like the fuel is cutting out on it. If you leave it less than 1/4 throttle it doesn't do this.
I've cleaned the carbs, replaced fuel filter and ensured good flow from the tank to the carbs.
Any other suggestions?
