Re: 1960 gale buccaneer 15hp
Just got a 1960 Gale 15 hp model # 15D 10B i want to used as a back up but it wont start . the person i got it from said it grand father had it and then is was give to him and he never used it. he said he tried start it a few time and it never start, don't look like there is any mix in the gas look like they were using it on straight gas trying to start the motor i clean the car. and put new plugs.
any suggestion why it not starting and where can i get parts for this old motor
If it still has the original coils under the flywheel it will have to have new ones.
Sierra Marine P/N is 18-5181 available thru marine dealers, NAPA Auto Parts, on-line and ad nauseum. Prices vary from $25 for a pair to $30 each depending on source.
But no point in spending the $ until you verify that it has enough compression to make it worth the outlay of cash.
The fuel system must be clean from gascap vent all the way to the reedplate.
CAUTION! that is a 24/1 fuel/oil mix motor! Do NOT be tempted to use less than 1/3 of a pint of TCW-3 oil to each gallon of gas no matter WHAT it sez on the oil container!!!
Study the following links to get yourself up to speed on reviving old OMCs.
<http://www.duckworksmagazine.com/01/articles/oldoutboards/index.htm>
<http://forums.iboats.com/showthread.php?t=299680>
