I have a 5.7 OMC with a Cobra drive but i have found out that the drive is the model for the 5.0. It has the 1.4:1 gears instead of the 1.5:1
The drive seems to be in pretty good condition. i never hear any weird noises or grinding. I changed the drive lube and didn't see any water but I checked the level the next 3 times out and the third time I did see some but it wasn't milk shake or anything. One more thing is the drive really needs to be painted.
But I was thinking that when I take the drive off this winter, pressure test it to find where the leak is, put new seal(s) in, change the impeller, maybe change the drive shift cable, paint it, and do whatever other maintenance is needed, I could post it on Craigslist and/or eBay and see if I could sell it.
If I don't sell it I will still have a drive with all the maintenance done for next season. If I can sell it I can get a 116 SEI drive and conversion kit and I will have a new drive with the correct gear set and a 3 year warranty. Plus SEI is just an hour away from me.
What do you guys think about this? Think the SEI drives are better than the Cobra I have now? Looking here at iBoats, and other Cobras I have saw I should be able to get enough for a SEI drive and conversion kit if I get the cobra all fixed up and painted right?
You guys think this would be a good idea?
Either way I will be doing the maintenance so the decision is not to spend the money on the Cobra drive, just whether I should switch to SEI if I can sell it, and if I will get enough for the SEI drive. (or near enough)
Aren't the Cobra drives sought by a lot of people with OMC drives that cant find them? The ones I have saw online are pretty expensive.
Open for all suggestions / opinions.
Thanks
Thanks
