I've got a big problem. A few weeks ago, I noticed a slight rattle in my lower unit while flushing the saltwater out in my driveway. I used it a couple more times with no problems.
Then yesterday, the lower unit made horrible grinding noises and obviously had big problems. The diagnosis, a bent prop shaft and I need a new lower unit.
When talking with the dealer, they said I must have hit something. However, the prop is absolutely pristine with no sign of damage whatsoever. It's under warranty, but I am told there is not way they will cover a bent prop shaft because you must have hit something.
My question, is there a way to get a bent prop shaft without hitting anything?
Thanks
Thanks
