redjmp
- Mar 16, 2005
- 536
I have a 78 898 pre alpha that came with a cracked block.
Replaced with an 85 305 from a car.
Reused the same heads and manifolds as they were not too bad.
But the starboard side now gets much warmer than the port side.
I have only run it for 15 mins total in 3 bursts of 5 mins all on muffs. Enough to get the temp to 140. The t-stat housing and lines to the bottom of the manifolds are cool. But the manifold under the t-stat is warm. Warmer the the port but cooler than the starboard risers.
The port side manifold gets warm quickly but even after 5 mins, I can still keep my hand on it but just barely. The big rubber hose that connects to the y pipe however is too hot to keep my hand on for more than a few seconds.
The other side is lukewarm at best.
So I removed the plug on the top riser and ran it and lots of water comes gushing out.
But it smells of exhaust. Is this normal?
So now I don't understand why this side gets so much warmer than the other.
Maybe its running normal and the other side is running too cool?
This is my first inboard so I am not sure if it should run that warm or not.
I tried to remove the port riser plug as well, but part of the skirt broke off making it almost impossible to remove.
Any ideas, suggestions, opinions or comments would be greatly appreciated!
