I recently inherited a 2003 Tracker boat, model Pro Guide V16. The boat is equipped with a 2003, 40hp Mercury, 2 stroke, 2 cyl. The prop is part number 48 815 704 A40 13P.
I filled the boat with gas, about 20 gallons. Took it for a test ride. I was the only person in the boat with no gear. The boat would not plane. The RPM was about 4500, max is 5500 RPM. I rplaced the plugs.
After a long ride and reducing the gas to 1/2 tank I finally got up on plane with 4700 RPM and 20 MPH.
A marine dealer suggested a 11 pitch prop.
Do you think the boat is underpowered.
