oconnellj3
- Aug 23, 2010
- 1
My 1998 Johnson 200 HP outboard won't turn off when the key is turned to the off position. The kill switch also will not shut it off. I replace the ignition switch and I still have the same problem. I can only turn it off by choking the engine out. Can someone verify the ignition electrical wiring? If it isn't the ignition switch or woring what is the problem? Thanks, Jim
