Re: overheated my motor
Common problem with the 120's , Replace the thermostat , pull the head check the head gasket , pull the exhaust manifold and you will probably find a blown gasket on it . This will allow water to build up in the lower cylinders . Head gasket is probably ok but better safe than sorry . The poor design of the exhaust manifold is the cause , no cure for it other than to use a OEM gasket that is thick , if you use a cheap low grade aftermarket gasket that is thin and waxy you will get to do this job again . While no one recommends sealer on the gasket I personally use SPRAY on Hi Tack from permatex , it is a red color and I spray each side of the gasket 3 times before installing . has worked well for me with no leaks. Do NOT use any kind of copper spray !! it will screw things up
