Ernest T
- Aug 29, 2009
- 367
Since the hull designs on these boats are so familiar, I thought I'd share some results that I got changing props and adding trim tabs to my boat (SD 2100 which is identical to the older 217 model) with the Yamaha F150 OB.
First off, I'd say that Hurricane and Yamaha have done a great job matching the best overall prop (Yamaha Reliance 17p 3 blade SS prop) with this boat/motor. The reasons that I was looking for a prop change was twofold: First I wanted to see if I could get the boat to plane at a lower speed that would make it easier to pull my kids on their wakeboards, and second because I managed to damage my original prop on a sandbar, and wanted a spare prop to keep on hand.
Thanks to Bear 69Cuda and NelsonQ for recommending the Smart Tab system instead of a prop change as a first step in helping me get the boat on plane faster. Smart Tabs are not like other trim tab systems, in that they are fully automatic. You don't have to fool around with hydraulic or electric controls and you don't have to worry about constantly adjusting them every time you change your speed or motor trim. They are also fairly cheap and easy to install. Once you mount and adjust them the first time, you can pretty much forget about them. I got the Protroller 1290 system for my boat with the 60 pound actuators http://www.nauticusinc.com/smart_tabs.htm, as recommended by Bear 69Cuda. Results with the Smart Tabs were impressive. The boat planned quicker, and would stay on plane around 3-4 mph less than without them. There was also significantly less bow rise at all speeds. The boat also runs more stable in the chop, which was an added benefit that I had not expected.
I was very pleased with the Smart Tabs and had decided to just go with a cheap aluminum prop for a backup, when I came across a very good deal on a PowerTech 4 blade SS 15p SkiMax prop http://www.ptprop.com/component/pag...acturer_id,0/option,com_virtuemart/Itemid,46/. The deal was too good to pass up, so I went ahead and got the PowerTech prop. I've now tested the 4 blade PowerTech and the original Yamaha props with and without the Smart Tabs engaged and my results are posted below. I hope this information helps other Hurricane owners with similar questions:
Original Setup: (Yamaha Reliance SS 17p Prop without Trim Tabs)
Max RPMs: 5800
Max Speed: 40.5 mph
Minimum Planning Speed: 19-20 mph
Holeshot: Average
Original Setup with Smart Tabs Engaged:
Max RPMs: 5700
Max Speed: 39 mph
Minimum Planning Speed: 15-16 mph
Holeshot: Above Average
4 Blade PowerTech SkiMax (MQS4) Prop without Trim Tabs:
Max RPMs: 5600
Max Speed: 37.5 mph
Minimum Planning Speed: 16-17 mph
Holeshot: Excellent
4 Blade PowerTech SkiMax (MQS4) Prop with Smart Tabs Engaged:
Max RPMs: 5600
Max Speed: 36 mph
Minimum Planning Speed: 14-15 mph
Holeshot: Excellent
NOTE: Right now I'm not quite reaching my max speed with the Smart Tabs engaged, which means that I probably have them set a little too "tight". I expect to see a little improvement in my top speed once I have the Smart Tabs dialed in correctly.
Max RPMs: 5800
Max Speed: 40.5 mph
Holeshot: Average
Max RPMs: 5700
Max Speed: 39 mph
Max RPMs: 5600
Max Speed: 37.5 mph
Holeshot: Excellent
Max RPMs: 5600
Max Speed: 36 mph
Holeshot: Excellent
