Drivesideways
- Jan 21, 2009
- 2
First off I have a 1993 challenger "Radical One" Bassboat. 20ft. It has an onboard charging system. The boat has a switch on bow that says 12v charge,12/24v run. I stepped on it and i broke it and I need to replace it. Is this a Challenger part, a Minn Kota part, or a part from the battery charger co.? There is no manufacturer info on the switch.
My trolling motor is only getting 12 volts and its a 24v motor.I have checked the obvious(battery connections and voltage, the wires.) There's a box that the main feed wires go to but I don't know anything about it to test it. There's 4 wires going in and alot coming out. Does anyone know which wire(s) should have 24 volts? Or explain how to diagnose?
