Hello everyone, we just got a 77 evinrude 4 cyl. model 115793 115HP motor running after about a 4 year rest. It was running when last put to rest. We changed the plugs oiled the cylinders, put in some new fuel mix and she started right up. We changed all the fuel lines, as we thought there was a leak. Still some fuel donw on the adapter plate.
I've done a searxh an could not find a similar poblem listed.
Looking at the carb end, the lower right side of the power head there is a port that is puffing out a oily gas mix. (looks unburnt) This is not the air silencer drain connecion, as that is intact. (A hose from the bottom right of the silencer to the bottom middle of the intake manifold)
The service manual I have does not show or mention this port. It is not a lot of fluid, but you can see the air puffs moving it along the the bottom of the adapter plate.
Is this normal? Should this be plumbed to the carbs? If I add a hose to the port, the engine will backfire a good amount (wet my whole hand) through the port.
The engine misses as I run up the RPM in neutral. I will be going over the ignition system with the help on the new service manual.
TIA, Mike
TIA, Mike
