Please. I want to get this boat back on the water and I can't find them. Thanks
L LIBoater123 Recruit Joined Aug 22, 2010 Messages 2 Aug 22, 2010 #1 Please. I want to get this boat back on the water and I can't find them. Thanks
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,616 Aug 22, 2010 #2 Re: NEEDED: Torque Specs 1993 175 Mercury connecting rod bearings If it a 2.5 175 see below.... 1st Torque - 15 lb-in (1.5 Nm.) 2nd Torque - 20 lb-ft (27 Nm.) Turn bolt additional 90 degrees after 2nd torque
E emckelvy Commander Joined Jan 16, 2004 Messages 2,506 Aug 22, 2010 #3 Re: NEEDED: Torque Specs 1993 175 Mercury connecting rod bearings Be sure to renew the rod bolts, these should be of the 'stretch' type and once torqued are permanently deformed. If you use old bolts they'll break and that tend to ruin one's day!!! HTH.........ed
