johnweeles
- Aug 22, 2010
- 13
I have a 1978 mercruiser 5.7 that has me stumped. I purchased the boat with a bad motor (water in the oil). I have since put a remanufactured engine in it and can't seem to keep it cool. It stays cool at an idle but slowly heats up when the rpms go over about 1800 regardless of whether or not it is on the hose or in the water and is slow to cool back down.
Checked with an IR gun. Thermostat housing slowly creeps up to 180 but the intake manifold near the housing stays at 160 or less. Log style exhaust manifolds seem to take turns running warm, one might be at 140 and the other creeps up to 190-200, then they alternate. The elbows stay cool however, running about 115 degrees when the manifold is cool to 150 when the manifold gets hot (200 degrees).
Has brand new alpha I lower unit with of coarse a new water pump, new thermostat, newer manifolds and elbows that don't seem to have any rust scale or flakes in them. New water pump on engine.
Almost forgot, this is seawater cooled and has only been run in fresh water. It has power steering also.
I am begining to wounder what the direction of flow is, but haven't found anything pertaining to something that old.
Thanks in advance to any replies.
