Eric Schultz
- Aug 22, 2010
- 3
Hello to everyone!
I have been around boats all of my life, but finally just bought one of my own.
It is a 1990 SeaRay 16" with a Mercury 115 4 cylinder.
I knew it had engine issues, but figured I could deal with it, since the price was pretty good.
When I bought the boat, the engine would run but would die as soon as put into gear (in the water). I found out that #2 piston was burned up.
OK.....so it looks like I need to bore out cylinder #2 and replace the piston. The rest of the engine looks ok. I need to find out why this happened, and make sure it doesn't happen again. I didnt find any obvious problems like dirt in the carb, a failed reed valve, ect.....
Am I missing anything? I have been into pretty many four stroke engines, but this two stroke thing is new to me.
Also upon removing the power head, it seems that the drive shaft is kind of tight when I try to turn it by hand, when it is in gear. is this normal? Could this be related to the problem with the engine?
Thanks for any and all help!!!
Eric
Eric
