capnstabbin
- Mar 17, 2010
- 120
1976 70 HP Johnson - Idles High after accelerating - Timer base sticks?
I've been with this motor for two seasons, I pretty much think I know it inside and out..... I have replaced a lot stuff, successfully may I add.
Before you mention it, I already have a repair manual from 1976
What happens is..... after accelerating in forward or reverse, obviously when you accelerate it advances all this timing, throttle cam, ......
When I come out of gear. she's idling pretty high. I usually have to take the cover off and push it all back about a 1/4 inch. then it idle right and I can put it into gear again with out worrying about blowing out lower unit.... or spilling my coffee... more importantly.
I have replaced everything but the actual cable back to the controls..... it seems loose....
Would the cable be a good place to start replacing... or should take off flywheel and see if its binding somewhere,,,, it all feels loose so I dont think its binding under the flywheel. I know I may have answered my own question but has anyone else delt with this problem.?
