My throttle control was sticking in neutral sometime,iwould give it a bump and it would work fine..i pulled the rubber button cover off and the plunger out to lub and now it will not go back in all the way, so i can put the rubber cover back on. It still shifts to foward and reverse and i can hold the plunger in at neutral and throttle up but the rubber button cover will not go on # i think its a volvo penta side mounted control #3885624, did i miss something??
