Anyone index their plugs? Notice any diff?
Todd157k
Being boat motors run at higher rpms than most cars, I was just wondering if anyone indexes their plugs and if so, notice any difference....?
Brewman61
Ensign
Re: Anyone index their plugs? Notice any diff?
What is indexing, never heard of it. Just curious.
dubs283
indexing plugs means facing the ground tabs in a certain direction for optimum fuel/air burn in the combustion chamber
the only engines i have heard of really needing this are DFI outboard engines, specifically Evinrude E-TEC engines. Merc Optimax engines do not require indexing of the plugs
the reason they index the plugs is due to the fuel being injected directly into the combustion chamber. the indexing aids in controling the direction of the burn across the pistion
i have never heard of indexing plugs on sterndrive engines and can't see any reason as to how this would aid in combustion/performance
EddiePetty
....I tried it on my 3.7 without any noticeable gains. I really don't believe our I/O's turn fast enough for indexing to be effective. Now on my former racing engines turning 7K+...the difference was noticeable: especially when we went injected!!
Edit:
Should and engine have leaking valve guides or other oil consumption problems, indexing could be used as a band-aid to reduce fouling until overhaul time......but it's just a crutch.
Ayuh,.... My sparkplug indexin' is done at the factory,...
Wherever Chevy taps the holes to, is where mine are Indexed....
bruceb58
Indexing is a complete waste of time.
Aloysius
Indexing is only applicable to certain conditions..one mentioned above, the other is physical clearance of the ground electrode and some part of the piston, only found on extreme racing engines.
a70eliminator
For your average run of the mill boat I agree, no noticable gain, but paying attention to detail never hurts.
Borchik
Indexing on sterndrives is very rare, high power direct injection efi setups use this, big race boats and stuff where it is a necessity. Certain DI outboards also does make a big difference. But for most stuff on the water there is no need.\\
Todd157k
Interesting. I didn't really ask "how" or "why". I know how, and why, and the benefits/theory.
I was curious because of the guys with large motors/drives. I know there's a lot of jet boat guys that index.. and yes, even on carb'd / blown motors.
