I have a 1984 Mercury 50 horse, had it on the lake just came up on plane heard a loud metal ping and have no power to the prop over idle speed, reverse still works fine. Several people suggested checking for a spun prop. The hub in my prop is welded in place with no rubber around it, pulled the prop and none of the splines show any sign of damage.
While checking the prop it was realized that the prop can be turned clockwise with little resistance while in gear. Should this be possible or is it an indication of a problem in the lower unit besides a spun prop??
Any suggestions would be greatly appreciated.
