1994 5.8l Fi Volvo hard to get started after warmed up
RodeoTrent
I have a 1994 210 Horizon, when its cold it starts up on the first crank. After running and getting warmed up, once i stop to swim or what not, if i let it sit more than a few seconds it will crank for about 10 seconds before finally starting up. and in this case if i go to take off right after (some times not all the time) it will back fire and feels like it has no power or sometimes die after i return to neutral. if i sit in neutral and rev it up a few times and try again it takes off with out any problems, maybe a little sluggish but no back firing, but the main issue seems to be the starting, its consistent as where the loss of power and back firing on take off is not......ANY advice would be greatly appreciated...
RodeoTrent
Re: 1994 5.8l Fi Volvo hard to get started after warmed up
forgot to say its a 94 OMC/Volvo Penta (Joint Venture) 5.8l Fuel Injection
JustJason
is it blowing any black smoke?
RodeoTrent
nope, no black smoke that i can see. but its all under water of course....
JustJason
You'd still see it, even if it was underwater. I won't be black smoke all the time, just when it's hard starting if it's doing what I think it is. Next time it acts up have someone start the boat while you hang your head over the back.
RodeoTrent
will do, ill be at the lake this weekend, what do you think might be the issue, what direction are u steering at....
JustJason
fuel injectors are leaking upon shutdown and flooding the engine out a bit. If it still hard starts put the throttle lever in neutral and open it up to full while cranking, that will clear the flood out.
RodeoTrent
sounds like a good idea, ill give it a shot, is there any way to test the injectors
RodeoTrent
nope no black smoke, weirdest damn thing i have ever seen, i see a few other post like mine, and no one seems to have a clue i also noticed i have lost about 7mph on wot as well
Danny Mc
If the eng is on computer a bad temp sensor signal will cause this prob., also if it has a mass airflo sensor and its dirty it can cause a bad reading.
RodeoTrent
the boat usually stays about 150 155, i dont know if that is hot or not, and this model doesnt have a Mass airflow sensor, just a throttle body with an IAC
haulnazz15
I would bet it has an air intake sensor of some sort. Also, the temp sensor for the ECU is NOT the same one used for the engine guage if I remember correctly. It would likely cause the ECU to run rich because it thinks the engine is cold.
RodeoTrent
so, where would i find this sensor, and how can i test it? what should this engines operating temp be? what your saying is u think the ECU is thinking the engine is cold because when its actually warm
Mohawkmtrs
In addition to the other suggestions, check fuel pressure (Key On, Engine Off), at Idle and for 5 minutes after shut-down. If pressure drops after shut-down, chances are leaking injector(s). If fuel pressure is not to specs., it may be a faulty fuel pressure regulator.
You may also want to check and clean the throttle body.
RodeoTrent
these are all good suggestions, im going to the lake this after noon, whats a cheap pressure tester cost?
Mohawkmtrs
If you're only going to use it once, it'll be cheaper to borrow/rent one.
RodeoTrent
Todd157k
First, I don't know your boat at all... but I do know FI real well. The above idea of being rich is probably true however one other thing that can cause this is bad temp sending unit. The ecu doesn't know the motor is warm/hot and keeps looking at the "cold" tables. Also, leaking injectors can also be caused by bad connections on the injectors themselves. Too high of fuel pressure will cause over-rich conditions as well.
Danny Mc
The IAC should be on the intake prolly behind and near the TB.
RodeoTrent
the IAC was replaced at the end of last year, its working fine, the boat idels great, i found the location of the intake air charge sensor , but i am having trouble locating the engine block temp sensor
