i have a 1956 evinrude lark, it has ran great for the last two years until just recently.The engine will start and run for 10 to 20 seconds then it reve's up high and shuts off. It will continue to idle if consistently pump the primer. After it takeing apart carburator and looking at it is in good working or i believe it is the rev limit switch. where can i get a replacement and/ or a part number or more modern year that will work. Or am i totally wrong and it could be something else. As well as where can i find a carb rebuild kit for that year 56' 30hp?
