My '72 1150 started a new behavior. We can be out all day fishing, no problems but when it comes time to load the boat, the motor keeps dying.
At first I thought mixture, but the motor didn't sputter or hesitate and stop, it was exactly like turning the key off.
The next time out we experimented, turning the wheel back and forth and every time when the steering wheel was at the exact same spot, the motor quit. Move the wheel, and it starts right up.
Since the wiring harness from the boat to the motor moves when the motor turns, I figured a wire was broken or shorting out.
I have pulled the complete control box and ext. wiring harness out and placed it on my living room floor. Everything looks in very good condition. The continuity meter and I have moved the wires every which way but no luck.
For the life of me, I can not find any broken wire or short.
I can think of only 3 wires that could cause this. The red (always on), black (ground) and the white (ignition which the key turns on). While running, these are the only wires that could shut the motor off.
Any ideas?
Thanks
Any ideas?
Thanks
