frustratedboater
- Jul 10, 2007
- 498
Greetings all,
I've got an issue that I'm stuck on and seeking assistance. I've aquired this motor 2002, 15hp (BF 15) which has been running in salt water. First of all, I'm not sure how much water this motor should be pumping. Starts fine, runs great... but the above water exhaust spout, in the back center of the motor, is just trickling out.
Things I've done to improve flow:
1) I've rebuilt the water pump. The impeller is spun correctly in the housing and all looks great.
2) I've checked/pulled the thermostat and it pours out of there when running briefly.
3) The small hose that squirts out the back right rear is blasting out.
4) I've tried compressed air up that spout and it just bubbles out near the prop when I do that.
I'm stumped!! Do I have to pull the powerhead to clear a water port or something?? I'd appreciate any suggestions,
~Frustratedboater~
~Frustratedboater~
