Re: 40 hp merc 4 stroke 2008
I checked your serial number and this motor is not affected by the recall campaign. You motor is under warranty till 12/14/10, so why not get it to a dealer and let them fix it while it's still covered? With the cover off, when you first key into the "run" position, do you hear the electric fuel pump cycle for a few seconds? You still could have a fuel pump issue. Based on what you stated earlier, if you turned the key to the "run" position and the fuse blew immediately, than you have a short somewhere. If now you turn the key on and it cranks but will not fire, this may be a seperate, but related issue. Get it to a dealer and let them chase the isssue. Part of the cost of a engine is the warranty. Why not take advantage of this?
