My 89 200hp Evinrude is showing 70psi on one cylinder and 89-90 psi on the other 5. I had the head off last year and saw no bad scoring of cylinder walls. I replaced the head gaskets then and have not ran it since. Today after rebuilding the carbs I ran it and found the above compression readings. I am doing a decarb to see if it is a stuck ring or carbon build up. If the copmpresion does not improve what would you guys suggest? Is this old of an engine worth putting much money into? The engine probably has 500-600 hrs on it.
Thanks for your help.
David
David
