wayupnorth
- Aug 16, 2010
- 7
'83 evinrude 100 hp
I went to take my boat out and lifted motor a tad (successfully) to release safety bracket and the motor would not drop... I was frustrated as we wanted to go fishing so I dropped the motor manually by loosening the threaded screw on the right side on the hydraulic system. Now, after reading several threads, I realize that I could be low on fluid, but the motor will not raise now as more fluid spilled when I manually lowered the motor. Is there a way to manually raise the motor in order to add more fluid?
Thanks,
Paul
Thanks,
Paul
