Re: buzzing solenoid?
Solenoid wasn't the problem. I am still stumped.
Mercury ELP 50 hsp two stoke, three cylinder.
About two months ago I noticed the gauges when traveling, in the boat, the would go dead, then magically come back up. Then a few weeks later I couldn't start the boat and noticed all the gauges are dead, key switch dead, trim switch on the shifter handle dead. When this happened I noticed that if I use the trim switch on the motor the gauges go back up and the motor will start with the key switch.
I am thinking feedback through a ground activated the gauges.
All the grounds are tight and the problem is getting worse. In a bulletin board I read the main harness has a tendency to short out. So I swamped out the main harness all 20 wires. Now the solenoid chatters like it is trying to open and close very fast and the intermittent gauge problem still exists. The two I think are related. A bad ground?
Yes, I put back the old main harness in and the solenoid chatter still exists. I swapped out the solenoid and it's good, still chatters.
The black/yellow ground on the solenoid is grounded to the voltage regulator. I moved the ground direct to the starter. Turned the key and it tried to start. However it started to smoke and the wiring became very hot.
Replaced a good solenoid
Tested the starter with jumper cables and it's good
Trim relays, good
Replaced a good voltage regulator
Rev limiter, good
Unplugged the stator and trigger, good
Replaced a good main cable harness
Replaced a good key switch
Oil sensor, good
All the grounds are tight.
Cables from the battery are good and tight.
I know my trim level gauge has a short in it. That shouldn't be affecting the solenoid. Maybe there is a bad wire from the key switch to the main harness in the motor? A short inside the throttle? Ideas? What causes a solenoid to chatter?
