Hello,
This motor was running great prior to replacing the pump impeller in the lower unit, when we changed the impeller we also replaced the two cables going to the shift solenoid as they were very work and falling apart in our hands.
When we got the motor back together it would not start with the key switch and the switch for the electric choke would not do anything. I took a wire and made a jumper across the solenoid and the motor cranked.
I did not do anything past this as I wanted to ask in case I'm missing something simple.
Thanks,
Erik
Thanks,
Erik
