79 1/2 90 hp it has 2 power packs an the 6 coils anyway i hooked a tech up on the rectafirer an a amp gauge to the dash insterments an its only reading 12.6 at 3000 rpm thats all i can get out of throttle an it bogs down pull it back alittle its fine .i just had carbs rebuilt an the whole fuel system replaced it starts now without spraying gas into carbs but doing samething it was at wot could the rectafirer cause this to happen ar what do i need to check for . the wireing in the control box has been gutted an they have a wire running from battey to fuse box an everything is on toggle switchs so only thing to motor is keyswitch tks in advance.
