Mercruiser 165 IL 6 camshaftdrife belt or chain?
popey
hi there,
I was just wondering, if my 165 IL6 (GM 250 cu) has a chain or a belt to drive the camshaft.
Does anyone know?
Thanks for your help.
Best Regards, Popey
vegasphotoman
Re: Mercruiser 165 IL 6 camshaftdrife belt or chain?
I would say CHAIN
belt drive cams are usually covered by a cheap plastic cover wherein the chain cam engines have a stamped metal cover.
the ford 2.3 liter has a belt, alot of japanese 4 cylinders have belts....
most of the 6 cylinders Ive ever seen have chains
(I was a dealer mechanic from 1986-1997)
hope that helps
popey
thanks for your reply
Howard Sterndrive
neither - it is gear driven
some with metal gears
some with fiber gears
zbnutcase
Yup gear driven!
popey
gear driven means no maintenance needed?
