Re: SEI vs. Mercruiser Alpha 1 rebuild
Hi MesaJeeper....a quick search resulted in this info....do a couple more searches and Im sure you'll get your answer...personally ME...I would go with the NEW SEI unit.....to heck with some local shop selling ya a couple parts and mebbe they warranty something...I would trust SEI over some local yocal shops warranty ANYDAY
welcome to Iboats
ps a buddy of mine has a new SEI and it DOESNT come with the bolts to bolt em together (the upper and lower) and a plastic tube for the water intake) so make sure if you do order one from somewhere that you get those parts as well....oh annd dont forget to ADD THE OUTDRIVEs LUBE! be a bummer to toast a new drive!
http://cgi.ebay.com/ebaymotors/MERCRUISER-OUTDRIVE-REPLACEMENT-BY-STERNDRIVE_W0QQcmdZViewItemQQcategoryZ124102QQihZ014QQitemZ330210272503QQrdZ1QQsspagenameZWDVW
THE BEST DEAL ANYWHERE ON A NEW
AMERICAN BUILT REPLACEMENT OUTDRIVE
BUILT BY THE WORLDS LARGEST SUPPLIER OF AFTERMARKET STERNDRIVES
FULL 3 YEAR WARRANTY BY MANUFACTURER
MANUFACTURES WARRANY CARD AND INFO INCLUDED
BUILT RIGHT HERE IN THE TAMPA AREA AND SHIPPED DIRECT TO YOU SO YOU ARE DEALING WITH A DIRECT SHIPPER THAT IS A POWER SELLER WITH 25 YEARS IN BUSINESS AND ONE OF THE BEST FEEDBACK RATINGS ON EBAY
ALL RATIO'S AVAILABLE 1.47,1.62,1.82 AND 1.94
THIS IS A GEN ONE REPLACEMENT
FOR GEN 2 ADD 200.00
FOR REVERSE ROTATION ADD 200.00
SHIPPED IN 2 BOX'S TO KEEP THE SHIPPING COST DOWN AND WE HIGHLY RECOMMEND THAT YOU ADD THE INSTALLATION KIT FOR PERFECT JOB. (also listed in our store.# 90-106-03K) COST 54.99
IF YOU NEED ANY HELP ON RATIO'S, STYLE [GEN 1 OR 2] REVERSE ROTATION, SHIPPING COST, ETC PLEASE EMAIL US AT:
hotrodgers@tampabay.rr.com
OR CALL 813-882-3227 IF YOU NEED ANY HELP BEFORE ORDERING
WE SUGGEST YOU ALWAYS CALL 1ST WITH THE FOLLOWING INFO
BOAT MAKE ,MODEL AND LENGHT AND YEAR
GEAR RATIO IF KNOW
ENGINE SIZE AND HORSEPOWER
OTHER INFO MAY BE NEEDED
IMPORTANT!!! IF YOU DONT CALL WE CANT HELP
ABOUT STERNDRIVE ENGINERING
Sterndrive Engineering (SEI) is the largest supplier of aftermarket stern drives in the world. The company makes replacement sterndrives for MerCruiser's? Alpha One? and Gen II stern drives. Sterndrive Engineering's outdrives are not remanufactured, they are entirely new. The SEI stern drive is made of parts that are completely compatible and interchangeable with MerCruiser's? Alpha One? and Gen II stern drives.
The stern drives are assembled at SEI's factory in Clearwater, Florida.
SEI's stern drives come standard with a three-year, fault-free warranty. This means that the unit is covered for any failure that requires the stern drive to be repaired or replaced. Run it without lubrication, crash into a stump, suck up some fishing line, it does not matter, the SEI stern drive is always covered. SEI believes this warranty is one of the best warranties ever offered for a stern drive. Peace of mind while on the water is important, and SEI goes the extra distance to make sure that our products perform.
SEI has done extensive testing on all of the parts of the stern drive including the gears, shafts, bearings, and other wear parts to confirm performance and durability. SEI operates one of the only research lakes in the world dedicated to the testing of marine propulsion systems. The research center has a 40-acre lake with a stationary dock that allows for around-the-clock endurance testing of parts, such as gears, shafts, and bearings.
Sterndrive Engineering has the best prices by far for a replacement stern drive compatible with MerCruiser's? Alpha One? and Gen II. Often the company is asked 'How do we do it?'. Sterndrive Engineering buys its parts directly from manufacturers and passes the savings on to the customer. The marine industry is notorious for multiple layers of distribution which adds cost to the end user. By avoiding the middleman, SEI is able to offer a quality stern drive at a fraction of the price offered by others.
IF YOU ARE LOCATED IN ONE OF THE ABOVE STATES THAT OFFER FREE SHIPPING, REQUEST AN INVOICE AND WE WILL REPLY WITH NO CHARGE ON SHIPPING
