Some wirng problems, Just got a new motor side wiring harness. The other one was so corroded and shot I couldnt compare to the new one. Not sure where each goes as I think there are more wires than the original. I hooked it up and no go. I jumped the starter solenoid and could get it to turn it over. Some help/verification with the wiring as it turned over before replacing wiring harness.
Upper Side:
Purple wire - choke solenoid
yellow/red with "clip end" - slide on bottom of neutral switch
black/yellow - tie/clip to other black/yellow
red-? maybe to the last screw above choke? 2 other red wires screwed there
Lower Side:
2 yellow/red - both on lowest nut on the starter solenoid?
Red wired tied together w/ fuse. - Upper right of the starter solenoid. (Where 12v ties in)
Black wire-? Middle right of starter solenoid.?
I remember a wire tieing to the bottom coil pack. Where did this wire go? The black wire doesnt seem long enough to reach over there. The red has too small of a end.
See attachment for harness used
Please help, Dont have the cash to take it to the shop.
Upper Side:
Lower Side:
