Re: 2 burned up starter solenoids in 1 week, HELP.
In the case of on old starter, there are several things that can wear out, yet the starter still may work. Worn out bushings, brushes, commutator, or a short somewhere in the armature windings will cause excessive amp draw.
Honestly, unless you own an amp meter that can handle 200+ amps with out blowing fuses or melting wires, testing it by your self isn't going to happen. Perhaps if you brought it to a place that rebuilds starters they can check the load draw. Autozone offers checks on alternators, and possibly starters, so thats another possibility. Obviously you wouldn't want to get a starter from Autozone for your boat though (I honestly wouldn't want to buy a starter for anything from Autozone). If your starter is the 1992 vintage unit, I would suggest replacing it anyway for piece of mind. Using a comparable marine grade replacement unit goes with out saying.
