oldgradywhite
- Sep 7, 2007
- 232
I have a 1989 50hp evinrude pro series. I rebuilt the carbs the right way and replaced the fuel lines from the vro to the carbs. It will crank and cranks then it will start briefly. Then stall like is out of gas. It will do this a few times then start blow a massive cloud of smoke and leave a big old slick of gas but it will run fine. When it?s warm I don?t have these problems. It does have a big miss at 2500 rpm range every once in a while but most of the time its fine. Looking for some input in to the problem its seems to be getting worse. Thanks
