1992 mercury 115 ***boating newbie***
kittyandfoot
Hello,
Brand new to boating and could use some help. Have a 1992 Mercury 115. Has clean fuel, new plugs, new fuel filter. Have adjusted the idle, to what should run good. Runs fine with the garden house, runs about 5 mins before I turn it off. Able to throttle up forward and reverse. As soon as I put it in the river, doesn't idle long. Was able to get in gear for about 100-200 yards then motor dies out. Any help would be greatly appreciated.
Dave1027
Re: 1992 mercury 115 ***boating newbie***
What rpm does it idle at in gear? Mine idles about 600 in gear (maybe as low as 500 if cold) and about 800 in neutral.
kittyandfoot
Not really sure, the RPM gauge works-ish. When I have seen it work, in idle I am about 800-1000 as low as 600 in idle.
