MdCrappie
- Jan 19, 2009
- 6
Trying to figure out how to adjust the Pilot Screws on my carbs. This is a 3 cyl 4 stroke. The manual says nothing about the screws.
My motor will stall when Idling for an extended time. I checked the screws and found the following:
Top Carb - seated
Middle Carb - 1.5 turns out from seated
Bottom Carb - seated
I'm guessing this is part of my problem
Other then not running after extended idle the motor runs great. Smooth acceleration and smooth running at all other rpm's.
Top Carb - seated
